Rename Filed in Feature class
966
09-18-2011 10:09 PM
MohammedBuali
HI,
can some one help me, i want rename a field name in an existed feature class?
i can only change the alias name using IClassSchemaEdit & AlterFieldAliasName method.
thank you.
NeilClemmons
Honored Contributor
You can't rename a field using ArcObjects.  You can, however, create a new field (and copy existing values to it) then delete the old field.  Depending on the datasource you may have other options - for instance, if it's a personal geodatabase you can open it in Access and rename the field.
JohnHauck
Please add you comments/feedback to the Make changes to fields after they have been created ArcGIS idea.
