Map Algebra and Python?
1202
09-02-2011 08:22 AM
ArvindBhuta
Hey all,
I'm trying to input two rasters and derive a "mean" raster from both of them.  The thing is I need to do this 4500 times.  Any help would be appreciated.  I've been messing around with a code, but I don't even know if I have it right.  Right now, it runs successfully but no output and I'm thinking this is because I forgot to define something?
Also, I don't know even if I can run it like the way I envision it?
What I'm trying to do is
mean (1895_01Tmin, 1895_02Tmax) = 1895_01Tmean
mean (1895_02Timin, 1895_02tmax) = 1895_02Tmean
mean (XXX_XXTmin, XXXX_XXTmax) = XXXX_XXTmean
I posted my code below and I really appreciate any help!
# Import system modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
gp.OverWriteOutput = 1
# Parameters
Workspace01 = gp.GetParameterAsText(0)
gp.AddMessage ("input Workspace01: " + Workspace01)
#Workspace01 = "C:\test\ppt_study_counties"
Workspace02 = gp.GetParameterAsText(1)
gp.AddMessage ("input Workspace02: " + Workspace02)
#Workspace02 = "C:\test\ppt_study_counties"
output_Workspace = gp.GetParameterAsText(2)
gp.AddMessage ("output Workspace: " + output_Workspace)
#OutWorkspace01 = "C:\test\zonal_stats_ppt_counties"
try:
    #Get the raster datasets in the input Workspace01 and loop through them from the start
    gp.Workspace01 = Workspace01
    InputRasters01 = gp.ListRasters01()
    gp.AddMessage(InputRasters01)
    InputRasters01.reset()
    InputRaster01 = InputRasters01.next()
    gp.AddMessage(InputRaster01)
    gp.Workspace02 = Workspace02
    InputRasters02 = gp.ListRasters02()
    gp.AddMessage(InputRasters02)
    InputRasters02.reset()
    InputRaster02 = InputRasters02.next()
    gp.AddMessage(InputRaster02)
    while InputRaster:
        #Set the output table name
        outRaster = OutputWorkspace + "\\" + Workspace01 + Workspace02 + "tmen"
        InExpression = "MEAN(Workspace01, Workspace02)"
        gp.AddMessage(outRaster)
        # Check out Spatial Analyst extension license
        #gp.CheckOutExtension("Spatial")
        # Load required toolboxes.  You may need to alter the paths if you are using a 64 bit OS
        #gp.AddToolbox("C:\Program Files (x86)\ArcGIS\ArcToolbox\Toolboxes\Spatial Analyst Tools.tbx")
        # Process: MapAlgebra
        gp.SingleOutputMapAlgebra_sa(InExpression, Outfile)
        # print InputRaster
        InputRaster = InputRasters.next()
except:
    gp.AddMessage(gp.GetMessages(2))
    print gp.GetMessages(2)
TonyPagani
Arvind,
Here is a script which should give you the mean of 2 rasters. The number of rasters in each of the workspaces must be the same or the script will error.
Regards,
Tony
gp = arcgisscripting.create(9.3)
# Parameters
#Workspace01 = r"C:\temp\test\Workspace1"
#Workspace02 = r"C:\temp\test\Workspace2"
OutWorkspace = gp.GetParameterAsText(2)
#OutWorkspace = r"C:\temp\test\outputwkspc"
try:
    #I removed the messages for easier reading of the code.
    #Set the environment workspace to workspace one. gp.workspace is an environment variable and must be set befor listing data
    gp.workspace = Workspace01
    InputRasters01 = gp.ListRasters()#This will list all the rasters in Workspace01
    gp.workspace = Workspace02#change the workspace to the next workspace you wish to list data for.
    InputRasters02 = gp.ListRasters()
    iterInputRasters02 = iter(InputRasters02)#create an iterater for rasters02 so it may be incremented.
    for InputRaster in InputRasters01:#This will loop through your first list.
        #Becasue the workspace was changed to create the second list the path to the first list is no longer valid. So the script does not fail
        #we need to set the full path name to items in InputRasters01.
        fullInputRaster = Workspace01 + os.sep + InputRaster
        InputRaster02 = iterInputRasters02.next()#increment
        nameRaster1 = gp.describe(fullInputRaster).baseName
        nameRaster2 = gp.describe(InputRaster02).baseName
        outRaster = OutWorkspace + os.sep + "mean" + InputRaster + ".tif"#create a tif with first raster name. Use a tif because the name could become too long for esri grid.
        InExpression = "MEAN(" + fullInputRaster + "," + InputRaster02 +")"#use the variable so the raster is updated for each SOMA call
        gp.SingleOutputMapAlgebra_sa(InExpression, outRaster)
except:
ArvindBhuta
Hey Tony,
I really appreciate it.  I'll check it out and run it through.  Looking forward to trying it.  Thanks a ton again!
Regards,
Arvind
