is reclassify from the spatial analyst toolset available at the python command line?
1242
7
08-26-2011 06:25 AM
AmelieDavis
Hi!
I'm trying to batch a bunch of files and have the following code:
arcpy.ReclassByASCIIFile_sa("D:/DATA/ILLINOIS/RFP_Landcover/Raster/chi_U19","C:/Users/Ams/Documents/SUM2011/recMap_chi_highres.txt","D:/DATA/ILLINOIS/RFP_Landcover/Raster/Reclass/Chi_U19_rc","DATA")
arcpy.ReclassByASCIIFile_sa("D:/DATA/ILLINOIS/RFP_Landcover/Raster/chi_U20","C:/Users/Ams/Documents/SUM2011/recMap_chi_highres.txt","D:/DATA/ILLINOIS/RFP_Landcover/Raster/Reclass/Chi_U20_rc","DATA")
I got the "code" from running it for one file and then using the "copy as python snippet" so it should work
but I get this error:
Runtime error <type 'exceptions.AttributeError'>: 'module' object has no attribute 'ReclassByASCIIFile_sa'
and when I try to get to the spatial analyst reclass tool in the command line by typing
arcpy.reclass only the ones from the 3D toolbox are available?
Does anyone know what I am doing wrong?  should I just use the 3D ones?
Any assistance is appreciated.
Amelie
PS Yes, I have checked that my spatial analyst toolbox is activated
AmelieDavis
I just used the reclassify_3d and that worked - I don't know why reclassify_sa is not available but as long as they both do the same thing I guess it's OK.
Is there any major difference between the 2?
ChrisSnyder
Honored Contributor
In arcpy there is a seperate sub-module for doing Spatial Analyst stuff... Try this:
arcpy.sa.ReclassByASCIIFile(blah, blah)
Other than different licensing requirements, I don't belive there is a differnce between these tools - I could be wrong though.
AmelieDavis
That worked!! Thanks a lot.  I do wonder still what the difference between the two is...
JasonScheirer
Esri Alum
The sa toolbox in arcpy behaves slightly different than other tools to support the Raster object and map algebra natively.
DanPatterson_Retired
to find out about sa functionality, simply get its help
>>> from arcpy import sa
>>> help(sa.ReclassByTable)
AmelieDavis
Is there a difference between using reclass in spatial analyst versus 3d?
ChrisSnyder
Honored Contributor
Sounds like in "backend" processing methodology: yes, in outcome: no.
