ArcObject Redline functionality in an ArcMap Add-in
2183
08-16-2011 01:08 PM
PaulLivingstone
Hi
I have a requirement to draw a freehand line graphic in an ArcObjects Add-in for ArcMap.
I want to simply draw on the map like drawing using a pencil in 'MS Paint'.
i.e. ringing features, creating a freehand arrow pointing to a feature on the map etc.
Then add a text description to indicate what is wrong.
Does anyone know what the best approach is for this or is this not possible?
Paul
DubravkoAntonic
Try this if it gives you some hint of drawing
http://forums.arcgis.com/threads/36292-How-draw-a-circle-arc-into-a-srcreendisplay?p=122707#post1227...
If you need persistent graphic you need to use drawing on the Graphic layer
Try something like this
            IGraphicsContainer container = (IGraphicsContainer)IMap.BasicGraphicsLayer;
            LineElement line = new LineElement();
            line.Geometry = pGeometry;
            IElementProperties props = (IElementProperties)line;
            props.Name = elemName;
            ILineSymbol pLineSymbol = new SimpleLineSymbolClass();
            IRgbColor pCol = new RgbColorClass();
            pCol.Red = color.R;
            pCol.Green = color.G;
            pCol.Blue = color.B;
            pLineSymbol.Color = pCol;
            pLineSymbol.Width = lineWidth;
            ILineElement lineElement = (ILineElement)line;
            lineElement.Symbol = pLineSymbol;
            container.AddElement(line, 0);
After drawing you need to refresh graphic layer
            IActiveView.PartialRefresh(esriViewDrawPhase.esriViewGraphics |
                                                esriViewDrawPhase.esriViewGraphicSelection,
                                                null, Extension.ActiveView.Extent);
Suggest to read in SDK more about drawing, without this will give you just more question then before.
