How can I do,with c# language, a "Select by location" between two shapefiles with the condition "are identical to"? I would like to do a button tool for ArcMap tha compare two shapefile end select the polygon that are identical or would be fine even those who are different.
Hi, I have read your post and test your code, it works fine but is too slow for me. I think that the problem is because I have more than 10000 record in the attribute table for each shape, than I had to add the function "SelectByShapeAndCheckIfEqual" in a loop:
Maybe it's not what I need? I'll explain what I should do! I have two shapefile refer to two different months, for example month_1 and month_2. I should look for differences alphanumeric (attribute table) and geometric between shapefile of month_1 and shapefile of month_2 and vice versa, mont_2 vs month_1. Than, save the new shapefile with the difference only.
Have you code to suggest me? Or link? Please help me!
