XML Workspace Import without Length field
1020
08-05-2011 12:09 PM
PaulAustin
Is it possible to get the XML import of a Workspace to not create a XXX_Length field? My XML document specifies the length field as blank <LengthField />. But both ArcCatalog and the arcobjects (Java) using GdbImporter both add a length field.
AlexanderGray
Honored Contributor
If you have a point or a table you will not get the length field.  Length is needed as part of the geodatabase for line or polygon featureclasses, it's a mandatory field.  Kind of like it needs an objectid and shape field (can have a different names.)   Polygon has an area field too.  Leaving these fields out would break the featureclasses.
PaulAustin
Are the length and area fields stored fields or are they calculated when displayed?
I know you can't update them from the ArcObjects API as you get an exception on them.
