Using Iterate Files in model builder to convert polygons to rasters
786
08-04-2011 09:25 AM
AlexBiggs
I'm trying to create a model that will run through a folder and convert several hundred polygons into rasters. Model builder will not allow me to set the File output by the iterator as the input for the Convert Polygon to Raster function without first specifying a file extension for files that it will iterate. I'm at a loss here since shapefiles are obviously made up of multiple files so I can't tell it to just use a single extension. Any advice?
JeffBarrette
If you don't get a reply soon, you may want to try posting this to the geoprocessing forum.
http://forums.arcgis.com/forums/31-Geoprocessing
Jeff
