ArcGIS API for Flex 2.4 just released :)
4720
12
07-28-2011 05:21 PM
BjornSvensson
Esri Alum
See Top-10 features of version 2.4 on the server blog at http://blogs.esri.com/Dev/blogs/arcgisserver/archive/2011/07/25/ArcGIS-API-for-Flex-and-ArcGIS-Viewe....  Then go to the "What's New" on the resource center to get the full story.
Tip: If you don't see the new pages, try emptying your browser cache, or wait a little for all our web servers to clear their caches...
baixuehong
When the database problem can be solved?Look forward this improvement!:)
BjornSvensson
Esri Alum
@baixueho,
What database problem?
VictorMilla
Wonderful new!!
Where can I download the viewer 2.4???
I have looked everywhere or do I just download the 2.4 API?
Heather Mounts
NC State Historic Preservation Office
BjornSvensson
Esri Alum
Go to the resource center at http://links.esri.com/flexviewer, click the "Download Viewer" link on the right side of the page (under Quick Links).
VijayashreeN
I am unable to see the real application it gives me lot of errors. Flex builder launch failed is the error that I am getting also
Description Resource Path Location Type
Could not resolve <s:ViewNavigatorApplication> to a component implementation. WebMap.mxml /flexapi2.4devver/src line 5 Flex Problem
Please help
ChristopherJennings
I'm receiving lots of errors (28 of them) when trying to create a new app based on the 2.4 source code:
-Description Resource Path Location Type
1120: Access of undefined property layoutDirection. WidgetTemplateSkin.mxml /FlexViewer/src/com/esri/viewer/skins line 42 Flex Problem
Plus more like this:
Cannot resolve attribute 'layoutDirection' for component type com.esri.viewer.BaseWidget. OverviewMapWidget.mxml /FlexViewer/src/widgets/OverviewMap line 21 Flex Problem
The error above applies to OverviewMapWidget, WidgetContainer, MapManagerSkin, and NavigationWidget
To create the errors I did the following:
1. Created new directory
2. Restarted Flash Builder using the new directory as my project directory
3. Imported src from 2.4 viewer directly from the .zip file using the "File --> Import Flex Project" menu option
4. Project attempts to compile then returns the errors
BjornSvensson
Esri Alum
Cannot resolve attribute 'layoutDirection' for ...
Christopher, it looks like you are compiling with Adobe Flex 4.0 SDK.  Starting with version 2.4 you need to use version 4.1 or higher.
From the What's New in 2.4 Viewer (under "General Changes"):
  • Compiling the source code [for ArcGIS Viewer for Flex] requires Adobe Flex 4.1 or above. This is to support Arabic and other right-to-left locales. Note that the API itself still works with 4.0, 4.1 as well as 4.5.
It's also mentioned briefly in the "Upgrading your viewer Code":
  • In version 2.4 of the Viewer, Adobe Flex 4.1 SDK is the minimum SDK version to compile with.
ChristopherJennings
Thanks, Bjorn. I'm definitely compiling w/ 4.0. That is the likely culprit.
earthmineinc
I developed a widget based on Flexviewer-2-3, and when I copy and paste it into the new flexviewer-2-4 environment and try to launch it the application crashes saying this :
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at com.esri.viewer.managers::WidgetManager/createWidget()
at com.esri.viewer.managers::WidgetManager/runWidget()
at com.esri.viewer.managers::WidgetManager/widgetReadyHandler()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at ModuleInfoProxy/moduleEventHandler()
at ModuleInfo/readyHandler()
at mx.core::FlexModuleFactory/update()
at mx.core::FlexModuleFactory/docFrameHandler()
at mx.core::FlexModuleFactory/docFrameListener()
Is there a way to make a 2-3compiled widget work with a flexviewer2-4 environment? (i mean other way than just recompile it with the 2-4environment source)
Thank for your feedback.
Alex
