ITopological Operator, Intermittent COMException on Union
5603
9
04-06-2010 09:51 AM
DavidPlume1
Hi Everyone, I'm getting intermittent errors on calls to the Union function for ITopologicalOperator.
The Error looks like this:
Error Source System.Runtime.InteropServices.COMException (0x80040218): Exception from HRESULT: 0x80040218   at ESRI.ArcGIS.Geometry.ITopologicalOperator.Union(IGeometry other)
Any ideas would be appreciated, I've found minimal info about this problem on the forums and documents online.
David
The code looks like this:
              '  Now work the geometry...
                Dim pNewPolyline As ESRI.ArcGIS.Geometry.IPolyline
                pNewPolyline = Nothing
                Dim pFeature As ESRI.ArcGIS.Geodatabase.IFeature
                Dim pTopoOp As ESRI.ArcGIS.Geometry.ITopologicalOperator5 = Nothing
                pComReleaser.ManageLifetime(pTopoOp)
                Dim pNewFeature As ESRI.ArcGIS.Geodatabase.IFeature = Nothing
                '  Featureset contains two or more sector line
                '  features that have the same assignment and belong
                '  to the same perimeter polygon.  Merge their shapes
                '  to create as single geometry from them.
                '  Get the feature metadata from the first feature.
                '  it will be used to populate metadata on the resulting
                '  feature.  Since all the line features are associated
                '  with the same polygon, they should all have the
                '  same metadata.
                Dim pMetadata As FIMTExtensionNET.clsFIMTMetadataNET
                pMetadata = Nothing
                FeatureSet.Reset()
                pFeature = FeatureSet.Next
                Do While Not pFeature Is Nothing
                    If pMetadata Is Nothing Then
                        pMetadata = New FIMTExtensionNET.clsFIMTMetadataNET
                        pMetadata.GetFeatureMetaData(pFeature)
                    End If
                    If pNewPolyline Is Nothing Then
                        pNewPolyline = pFeature.ShapeCopy
                        pTopoOp = CType(pNewPolyline, ESRI.ArcGIS.Geometry.ITopologicalOperator5)
                    Else
                        pNewPolyline = pTopoOp.Union(pFeature.ShapeCopy)  '<<<<<<<<<<<<<<<<<<<<< Where the Exception is thrown.
                        pTopoOp.Simplify()
                    End If
                Loop
KirkKuykendall
Try simplifying the geometry before passing it as an arg to Union.
DavidPlume1
Hi Kirk,
Thanks, that may have worked.   For the sake of the thread here's what I've tried:
I spoke with ESRI yesterday via an incident and they thought I should try to replace  explicitly set a variable = pFeature.ShapeCopy and use that value in the arguments to pTopoOp.Union().  The problem persisted after that.
I then implemented your recommendation and so far things seem to be working.  The troubling thing about this error is how it is intermittent so I can't yet say for sure but things look good so far.
For the sake of the thread, here is the code as it stands now:
                Dim pNewPolyline As ESRI.ArcGIS.Geometry.IPolyline = Nothing
                Dim pOtherPolyline As ESRI.ArcGIS.Geometry.IPolyline = Nothing
                '  same metadata.
                pMetadata = Nothing
                FeatureSet.Reset()
                    End If
                    Else
                        pOtherPolyline = pFeature.ShapeCopy  ' This didn't seem to help....
                        pTopoOp.Simplify()                            ' This may have solved the prob.
                        pNewPolyline = pTopoOp.Union(pOtherPolyline)
                        'pNewPolyline = pTopoOp.Union(pFeature.ShapeCopy) 'OLD CODE
                        'pTopoOp.Simplify() 'OLD CODE
                    End If
                Loop
KirkKuykendall
I think you should set ITopologicalOperator2.IsKnownSimple_2 to false before calling Simplify().
(ESRI sure needs to simplify this process of simplification).
Also, I've had issues with Union for polygons that contain circulararc segments.  The workaround was to call IPolyCurve.Densify.  Doesn't seem like this should pertain to polylines, but might be worth trying.
DavidPlume1
Thanks again Kirk, I've added your recommended code with good success.  I've run through the problem scenario about 10-15 times with no COM Exception thrown.  We might be there!
DavidPlume1
For those who are interested, a bit more information:
If one cannot ensure that the polyline created is not simple then we need to call the simplify method. A geometry is not simple when it does not meet the all the constraints associated with them. The following documentation explains how the simplify method simplifies the geometry.
http://resources.esri.com/help/9.3/ArcGISDesktop/com/samples/Geometry/e7840a7a-f228-46d2-9c45-81dd55...
http://resources.esri.com/help/9.3/ArcGISDesktop/ArcObjects/esriGeometry/Geometry_overview.htm
http://resources.esri.com/help/9.3/ArcGISDesktop/ArcObjects/esriGeometry/ITopologicalOperator_Simpli...
BenStewart
I'm having similar problems, but with the ItopologicalOperator intersect. I have tried the suggestions here about simplification, which helped, but, in the end, the code still errors with an unknown COMException.
The basic idea is to find the distance to the nearest line feature in a single direction. This is accomplished by creating a line segment from the starting point to another point 10000000m away along the direction specified and intersecting with the line feature class. The distance to all intersections is calculated, and the minimum is stored.
The code will work for about 3000 features then crash, when I restart it works for the feature it crashed on (it only processes features not processed yet). Any suggestions would be welcomed.
           'Set these values at the start
            Dim azimuthField, distanceField As Long
            azimuthField = form.inputField
            distanceField = form.OutputField
            ' Get map object
            Dim mxd As IMxDocument
            Dim map As IMap
            mxd = CType(m_application.Document, IMxDocument)
            map = mxd.FocusMap
            'Get feature classes, first is points, then borders
            Dim ptLayer As IFeatureLayer
            Dim borderLayer As IFeatureLayer
            Dim ptClass As IFeatureClass
            Dim borderClass As IFeatureClass
            ptLayer = form.InputLayer
            ptClass = ptLayer.FeatureClass
            borderLayer = form.BorderLayer
            borderClass = borderLayer.FeatureClass
            ' loop through each point feature
            Dim featCur As IFeatureCursor
            ' This is a search to ensure that only non-processed features are processed
            Dim filt As IQueryFilter = New QueryFilter()
            Dim f As IField = ptClass.Fields.Field(distanceField)
            filt.WhereClause = f.Name + " = 0"
            featCur = ptClass.Update(filt, True)
            Dim feat As IFeature
            feat = featCur.NextFeature()
            Dim pt As IPoint
            Dim azimuth, dist, i As Double ' This will store the azimuth direction
            Dim maxDist As Double
            Dim tempSegs As ISegmentCollection = New Polyline()
            Dim tempSegsGeog As IGeometry
            Dim tempFeat As IFeature
            Dim topo As ITopologicalOperator5
            Dim prox As IProximityOperator
            Dim geomTemp As IGeometry
            maxDist = 100000000
            Try
                While Not feat Is Nothing
                    maxDist = 100000000
                    pt = feat.ShapeCopy
                    azimuth = CDbl(feat.Value(azimuthField))
                    Dim tempLine As ILine
                    ' This function creates the temporary line feature used to intersect
                    tempLine = createTempLine(pt, CDbl(azimuth))
                    'The line needs to be wrapped in a polyline to fit in the spatial filter
                    If tempSegs.SegmentCount > 0 Then
                        For i = 0 To tempSegs.SegmentCount - 1
                            tempSegs.RemoveSegments(i, 1, False)
                    End If
                    tempSegs.AddSegment(tempLine)
                    tempSegsGeog = tempSegs
                    tempSegsGeog.SpatialReference = feat.Shape.SpatialReference
                    Dim spatial As ISpatialFilter = New SpatialFilter()
                    spatial.SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects
                    spatial.Geometry = tempSegs
                    ' A spatial query is used to get the intersetion points, I thought this is where the memeory leak was happening, but I don't think so anymore (after examining the call stack
                    Dim tempFeatCur As IFeatureCursor = borderClass.Search(spatial, True)
                    tempFeat = tempFeatCur.NextFeature()
                    While Not tempFeat Is Nothing
                        topo = tempFeat.Shape
                        topo.IsKnownSimple_2 = False
                        topo.Simplify() ' attempt to fix intermitent error following http://forums.arcgis.com/threads/1992-ITopological-Operator-Intermittent-COMException-on-Union
                        'This is where the error is occuring, at least it is for the first time
                        geomTemp = topo.Intersect(tempSegsGeog, esriGeometryDimension.esriGeometry0Dimension)
                        prox = geomTemp
                        dist = prox.ReturnDistance(pt)
                        If dist < maxDist Then
                            maxDist = dist
                        End If
                    End While
                    System.Runtime.InteropServices.Marshal.ReleaseComObject(tempFeatCur)
                    System.Runtime.InteropServices.Marshal.ReleaseComObject(tempLine)
                    feat.Value(distanceField) = maxDist
                    featCur.UpdateFeature(feat)
                End While
            Catch ex As System.Runtime.InteropServices.COMException
                System.Windows.Forms.MessageBox.Show(ex.Message)
            End Try
            System.Windows.Forms.MessageBox.Show("Finished Calculating Distances")
        End If
KirkKuykendall
You might try calling IGeometry.SnapToSpatialReference before simplifying.
Also, intersect can flake out with nonlinear segments, so maybe call IPolyCurve.Densify before Intersect.
DavidPlume1
Hi Everyone,
For the sake of completion in this thread, we solved our particular problem by simplifying all of the input features and by simplifying the resulting feature on each iteration of the while loop:
            Dim pFeature As ESRI.ArcGIS.Geodatabase.IFeature = Nothing
            '  same metadata.
            pMetadata = Nothing
            FeatureSet.Reset()
                End If
                    pTopoOp.IsKnownSimple_2 = False '051710
                    pTopoOp.Simplify() '051710
                Else
                    'Simplify the just obtained OtherPolyLine
                    pTopoOp = CType(pOtherPolyline, ESRI.ArcGIS.Geometry.ITopologicalOperator5) '051710
                    pTopoOp.Simplify()
                    'Reset the pTopoOp to pNewPolyLine in prep for the union
                    'Simplify the resulting New Line
                    pTopoOp.Simplify()
                End If
            Loop
I hope this is helpful.
D
DuncanHornby
MVP Notable Contributor
All,
Very useful thread this, it saved me!
I was getting the same COM error, found this thread, implemented Simplify and IsKnownSimple_2 but was still getting the error. I eventually solved it by adding a SimplifyNetwork of my polylines that I was attempting to do the Symmetrical difference on. So for the record my full code snippet is:
pPolylineStart.SimplifyNetwork()
pPolylineTest.SimplifyNetwork()
pTopoOp = pPolylineTest
pTopoOp.IsKnownSimple_2 =False
pTopoOp.Simplify()
pPolyline = pTopoOp.SymmetricalDifference(pPolylineStart)
Duncan
