Data Frame Extents with vb.net
1086
07-14-2011 06:57 AM
paulkarwinski
can anyonme help with the following problem
using i want is to set the following dataframe options
manually i would set
extent used by full extent command  to other
then specify extent , the set custom extents
I just want to be able to do this with vb.net, but can't work out how to set the these option. I can do everything else with the dataframe but can't figure how to do these final options
thanks
paulkarwinski
forgot to mention extents option on the data frame set to automatic
