help needed with python FOR loop.
1643
6
06-30-2011 09:47 AM
AliceDeschamps1
I need help getting this For loop working.  Not even sure if what I am trying to do is possible or if a For loop is the best way to get it done.  Can I use input parameter to set the range in my for loop?
The codes below worked fine before I added the for loop.  Once I add my loop it skips to the last line in the code and prints "The Extract Flood and Convert to Vector tools is completed!!".
This is running as a script tool and users are asked to define their environment setting before launching the tool.
Thanks.
Alice
# Import arcpy module
import arcpy
from arcpy import env
from arcpy.sa import *
import sys, string, os
# Script arguments
    inRaster = arcpy.GetParameterAsText(0)
    minThr = arcpy.GetParameterAsText(1)
    maxThr = arcpy.GetParameterAsText(2)
    minHa = arcpy.GetParameterAsText(3)
    arcpy.env.mask = arcpy.GetParameterAsText(4)# Set Geoprocessing environments
    for i in range(int(minThr), int(maxThr)):
outputShapefile= os.path.splitext(inRaster)[0] + "_thr" + str(i) + "_" + str(minHa).replace('.','p') + "ha.shp"
        whereClause = '"Area_ha" >=' + minHa
        waterSql = '"Value" > 0 AND "Value" <=' + int(i)
         # Process: Con (needs spatial analyst license)
        outCon = Con(inRaster, 1, 0 , waterSql)
        outCon.save("outCon")
        arcpy.AddMessage("Open flood extent map is created (raster)")
        # Process: Focal Statistics (5x5 Mode)
        outFocalStats = FocalStatistics(outCon, "Rectangle 5 5 CELL", "MAJORITY", "DATA")
        outFocalStats.save("outFocalStats")
        arcpy.AddMessage("Image is filtered")
        # Process: Convert Raster to Polygon
        arcpy.RasterToPolygon_conversion(outFocalStats, "Raster2poly.shp", "NO_SIMPLIFY", "")
        arcpy.AddMessage("Converted to vector")
        # Process: Select Gridcode >0
        arcpy.Select_analysis("Raster2poly.shp", "Raster2polyCode0.shp", "GRIDCODE >0")
        # Process: Add Field to Calculate Area
        arcpy.AddField_management("Raster2polyCode0.shp", "Area_ha", "FLOAT", "", "", "", "", "NON_NULLABLE", "NON_REQUIRED", "")
        # Process: Calculate Field: Area in Ha
        arcpy.CalculateField_management("Raster2polyCode0.shp", "Area_ha", "!Shape!.area/10000", "PYTHON_9.3", "")
        arcpy.AddMessage("Area calculated (ha) for flooded polygons")
        # Process: Select min polygon size
        arcpy.Select_analysis("Raster2polyCode0.shp", outputShapefile, whereClause)
        arcpy.AddMessage("Applying the minimum hectare size")
        # Process: Delete intermediate files
        arcpy.Delete_management("outCon", "")
        arcpy.Delete_management("outFocalStats", "")
        arcpy.Delete_management("Raster2poly.shp", "")
        arcpy.Delete_management("Raster2polyCode0.shp", "")
        arcpy.AddMessage("Intermediate files deleted")
arcpy.AddMessage("The Extract Flood and Convert to Vector tools is completed!!")
AliceDeschamps1
The identations in the code did not come out in my post.  All lines after "for i in range(int(minThr), int(maxThr)):" are indented except for the last last Add.Message statement.
DanPatterson_Retired
edit your original post and throw the script within code blocks (the # symbol in the html editor)
AliceDeschamps1
It looks fine in edit mode?  Not sure how to set it within code block?
ChrisSnyder
Honored Contributor
Just select your code text and click the little "#" button (3rd to the left of the YouTube button).
AliceDeschamps1
Maybe I should be more specific in my question.    Can I use my parameters to define my FOR loop range as I have tried to do below or am I completely wrong?
If that is not possible then the other option I can see is it to use a FOR loop to iterate over a list. That means that I need to build a list from the minThr and maxThr parameters first.  Not sure how to do that either?
Any suggestions would be greatly appreciated.
Alice
AliceDeschamps1
Got it to work.... solved!
