Map Initialization Lifecycle
2648
06-23-2011 12:01 AM
JH2
Hi all,
As my map loads, I run through some initialization; applying the correct extent to the map and putting some data into a GraphicLayer.
Is there a standard way to check/listen for initialization?
I've been using the
Map.Initialized
event but, for example, the Map.SpatialReference (which I need to know to calculate the extent) and the Map.Layers aren't ready at this point.  I've also tried the
Map.Layers.LayersInitialized
event, which correctly lets me know when the Graphics layer is ready for data, but there is no Map.Layers.IsInitialized property for me to check.  (I'm building Behaviors so I don't necessarily know if I've been attached at init or at a later stage.)  It also seems a bit weird to check this when waiting for the Map.SpatialReference to be ready, but I guess that perhaps this value comes from the Layers?
Just wondered if there was a resource describing this lifecycle or any recommendations on how to deal with it?  Any thoughts or suggestions gratefully received!!
James
DominiqueBroux
Esri Frequent Contributor
If you don't set the map spatial reference, this one is coming from the layers, and so we need to wait for them to be initialized.
Right, but you can check the 'IsInitialized' property of each layer inside the collection.
Subscribing to Map.Layers.LayersInitialized is one way to do what you want, another would be to subscribe to Map.PropertyChanged and test whether the "SpatialReference" property has changed.
JH2
That makes sense and clears it up - just wanted to make sure I hadn't missed anything!
Cheers,
James
