Avoid certain street types
802
5
06-15-2011 05:01 AM
MartinaRagettli
Hi
I would like to avoid highways or main roads when doing "best route analysis" (impedance: shortest route). What is the best and easiest way to implement this restriction?
JoeBorgione
Hi
The best and easiest way is what works for you.  A couple of suggestions:
Create a network feature dataset WITHOUT your highways and main roads
Place barriers on each  (yuck)
Place impedance values on them like low speed limits (if you are minimizing travel time)
Hope this helps-
MartinaRagettli
Thank you for your suggestions.
It would be also nice to add a restriction attribute for the highways and add a parameter on the restriction. Something like that: with a car, the highways are transferable, by foot not. The mode would be the parameter. However, I'm not sure if this is possible to do. So far, I did not manage to implement this. The option "parameters" in the Network Dataset properties was always inactive (???).
What do you think?
MartinaRagettli
To your suggestion "Place impedance values on them like low speed limits". How would you do that? By creating a new cost attribute? How would you then set the evaluators?
Thank you so much
JoeBorgione
Thank you so much
I'm sorry, I don't have the time and this forum dosen't have the space for a complete description of Network Analysis.  Assuming you are using ArcGIS 10.x may I suggest you start here, and if you are using 9.3, take a look here.
There are a couple of tutorials out there too: just google network analyst tutorial and you'll find them.
Typically, the street centerline data I use in the network have various attributes that I can use in NA.  For example SpeedLimit.  With it you can do a calculation with the segment length to derive a 'cost' of travel time needed to traverse any given street segment.  In my case, I keep freeways at 65 mph; it sounds like you may want to knock them down to 1 mph, thus making traversing the freeway segments unattractive to the solver if travel time is to be minimized.
AlexeyTereshenkov
Joe, good point.
I agree with Joe, the best way for you to get started is to become familiar with the concepts first. I bet you will find all your questions answered in the Help, it is very comprehensive.
ArcGIS Network Tutorial is available online at:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Exercise_1_Creating_a_network_dataset/...
Or as .pdf file:
http://help.arcgis.com/en/arcgisdesktop/10.0/pdf/network-analyst-tutorial.pdf
Good luck.
