Intersect Selected Features VBA
1016
06-10-2011 10:26 AM
IRASEMAANGELES
Hi i have this code to intersect 2 layers but i want to intersect the selected features in one layer.
Public Sub Intersect()
' Get the input layer and feature class.
Dim pMxDoc As IMxDocument
Set pMxDoc = ThisDocument
Dim pLayer As ILayer
Set pLayer = pMxDoc.FocusMap.Layer(0)
Dim pInputFeatLayer As IFeatureLayer
Set pInputFeatLayer = player
' Use the Itable interface from the Layer (not from the FeatureClass)
Dim pInputTable As ITable
Set pInputTable = player
' Get the input feature class.
' The Input feature class properties, such as shape type,
' will be needed for the output.
Dim pInputFeatClass As IFeatureClass
Set pInputFeatClass = pInputFeatLayer.FeatureClass
' Get the overlay layer
Set pLayer = pMxDoc.FocusMap.Layer(1)
Dim pOverlayTable As ITable
Set pOverlayTable = pLayer
' Error checking
If pInputTable Is Nothing Then
MsgBox "Table QI failed"
Exit Sub
End If
If pOverlayTable Is Nothing Then
Exit Sub
End If
' Define the output feature class name and shape type (taken from the
' properties of the input feature class)
Dim pFeatClassName As IFeatureClassName
Set pFeatClassName = New FeatureClassName
With pFeatClassName
.FeatureType = esriFTSimple
.ShapeFieldName = "Shape"
.ShapeType = pInputFeatClass.ShapeType
End With
' Set output location and feature class name
Dim pNewWSName As IWorkspaceName
Set pNewWSName = New WorkspaceName
pNewWSName.WorkspaceFactoryProgID = "esriCore.ShapeFileWorkspaceFactory.1"
pNewWSName.PathName = "C:\temp"
Dim pDatasetName As IDatasetName
Set pDatasetName = pFeatClassName
pDatasetName.Name = "Intersect_result"
Set pDatasetName.WorkspaceName = pNewWSName
' Set the tolerance. Passing 0.0 causes the default tolerance to be used.
' The default tolerance is 1/10,000 of the extent of the data frame???s spatial domain
Dim tol As Double
tol = 0#
' Perform the intersect
Dim pBGP As IBasicGeoprocessor
Set pBGP = New BasicGeoprocessor
Dim pOutputFeatClass As IFeatureClass
Set pOutputFeatClass = pBGP.intersect(pInputTable, False, pOverlayTable, False, tol, pFeatClassName)
' Add the output layer to the map
Dim pOutputFeatLayer As IFeatureLayer
Set pOutputFeatLayer = New FeatureLayer
Set pOutputFeatLayer.FeatureClass = pOutputFeatClass
pOutputFeatLayer.Name = pOutputFeatClass.AliasName
pMxDoc.FocusMap.AddLayer pOutputFeatLayer
End Sub
i change this line false for true but the code ignore the selection. I hope somebody can help me i need this code so mucho thanks!!
