Schedule a script: ImportError: No module named arcpy
2582
5
06-06-2011 04:49 AM
deleted-user-VeZur_n9o0OZ
Hi folks,
I've added a script to a toolbox that I'd like to run every X minutes as a scheduled task. If I try and run my .py file from command line I cannot import arcpy:
[HTML]ImportError: No module named arcpy[/HTML]
Same message if I try and run the script in PyDev for Eclipse, or Idle. I've read this thread but with no joy.
Info
I'm on Windows 7, 64bit
this folder exits: C:\Python26\ArcGIS10.0
I don't know where Desktop10.pth file is?
I have no PYTHONPATH variable
Any pointers appreciated!
James
Update:
I have located Desktop10.pth here:C:\Python26\ArcGIS10.0\Lib\site-packages. It contains these entries:
C:\Program Files (x86)\ArcGIS\Desktop10.0\bin
C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy
C:\Program Files (x86)\ArcGIS\Desktop10.0\ArcToolbox\Scripts
Am i right in saying I need to reference arcpy somewhere centrally so python.exe can run my scripts outside of ArcGIS?
James
AlessandroCinnirella
how do you type your command?
if you don't add "python.exe" to your PATH system variable, you must specify it in the command line:
c:\Users\Yourname> c:\Python26\ArcGIS10.0\python.exe yourscript.py
ciao,
AC
RuthEmerick
See http://www.itechtalk.com/thread542.html for instructions on how to add the Python directory to your system's path variable.
Thanks guys. I was running C:\Python26\python.exe in my bat file so have now changed this to C:\Python26\ArcGIS10.0\python.exe. Also, in PyDev preferences (Window > preferences > PyDev > Interpreter Python > I've updated interpreters to reflect this so I can now run my scripts in Eclipse. I ran the bat file successfully as a scheduled task all night.
Ruth, I have appended ';C:\Python26\ArcGIS10.0' to my Path environment variable. Is that correct? Should that resolve the following:
my script fails If I run it from windows explorer (double clicking it).
I receive the following message running my script in IDLE:
import arcgisscripting
ImportError: DLL load failed: %1 is not a valid Win32 application.
Cheers,
James
RuthEmerick
Check and make sure that the C:\Python26\ArcGIS10.0\Lib\site-packages\Desktop10.pth file contains the following two lines (you can edit it with Notepad):
C:\Program Files\ArcGIS\Desktop10.0\bin
C:\Program Files\ArcGIS\Desktop10.0\arcpy
If not, add them. Hopefully that's the problem.
