points sampling
6267
6
05-19-2011 01:14 PM
MilanBudhathoki1
Hi everyone,
I have 35,000 points datasets. It is tedious to incorporate all points for my analysis. I am trying to generate random sample points in ArcGIS 9.3.1 platform. Is it possible run sampling technique in ArcGIS 9.3.1?
Thanks!
SteveLynch
Look at "Create Subsets" in 9.3
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?id=4003&pid=3999&topicname=Extending_ArcMap_with...
or add a field to your dataset and use the "Calculate Field" GP tool using the following Python expression
arcgis.rand("Integer 0 100") (you'll have to modidy the 0 100)
or in ArcGIS 10, use the Subset Features GP tool
-Steve
MilanBudhathoki1
Thank you Lynch !
Your instruction was handy.
MalenaVargas
I dont have Geoestatistical analyst and I want to make a random selection over points. I need help urgently!!!
TarunJaiswal
You can always get a 60 day trial version of Geostatistical Analyst.
EricKrause
You can also use Python's random number generator to get random subsets.
Let's say you have 100 points in your feature class, and you want a subset of 70 random points.  Make a new Short Integer field in the feature class, then use Calculate Field.  Make sure you change from VB to Python, and use this code:
arcgis.rand("Integer 1 100")
Then sort the Attribute table by the random number, and select the first 70 records.
SteveLynch
or you can read the post (05-19-2011 02:13 PM) in this thread
Steve
