how to use a variable as an object property in python
1405
5
05-05-2011 08:52 AM
lukestudden
Hi all,
I am using python (9.3) to automate the creation of numerous Featureclasses. Along the way I am adding a new column (field) to each which the field name is essentially a variable as it is all data driven. I am then using the UpdateCursor to update the value of the field with the value of another within the same Feature class. The problem is that since the field name I have added is a variable, I can not use the update cursor to refer to it as it changes after each loop iteration. Is there any way you can use a variable as an objects property, eg.
instead of explicitly stating the field to be updated eg. updaterow1.car1 I would like to use a variable eg: updaterow1.carnumber
Carnumber would then change after each iteration eg. car1, car2, car3 etc.
Is this possible?
Thanks!
LoganPugh
See Accessing Data Using Cursors. Particularly the setValue and getValue methods.
lukestudden
Hi Logan,
thanks for the reply. I am still struggling to see this. Could you shed any more light on this at all? I would be most grateful! Below is a simplified version of what I have;
fieldname = "car "+ str(incrementingcounter)
updaterows1 = gp.updatecursor(outputpoly1)
updaterow1 = updaterows1.next()
    while updaterow1: # selects the entire row, but row has properties hence .fieldname
        #### i essentially need this to be something like updaterow1.fieldname
        updaterow1.count_0 = updaterow1.Join_Count
        updaterows1.updaterow(updaterow1)
del updaterows1
LoganPugh
There are two basic ways to get and set field values on a row:
    * Using the field name, as in value = row.road_type
    * Using getValue and setValue, as in value = row.getValue("road_type")
Try using the getValue and setValue methods instead of using field names as properties.
lukestudden
Does that mean i can use:
Row.getvalue(fieldname)
As a direct replacement of what i am currently using?
Updaterow1.car1
LoganPugh
Yes, they work the same way except that they allow you to pass a variable for the field name instead of hardcoding it.
