set order on multiple fields
1433
04-20-2011 10:00 AM
TerrySilveus
I'm doing this
rows = arcpy.UpdateCursor("c:/gis/temp.shp","","","","POINT_X A, POINT_Y A")
I want to sort on both POINT_X and POINT_Y fields, but it doesn't seem to be working.  Can someone let me know how to sort on multiple fields in a cursor?
ChrisSnyder
Honored Contributor
Try this:
rows = arcpy.UpdateCursor("c:/gis/temp.shp","","","", "POINT_X A; POINT_Y A")
The correct sort field parameter delimiter is a ; and you were using a ,
TerrySilveus
Try this:
That did it.  Thanks so much.
DonnaBest
I need to sort on multiple fields in vb.net.   Any ideas?
Thank you!
TerrySilveus
Thank you!
In a vba (from access experience not sure how it would be in arcMap) sql statement you just use commas between fields
SELECT ... FROM ... WHERE ... ORDER BY field1, field2 ...
not sure about vb.net
