ISelectionSet2 automation Error?
1511
04-14-2011 11:59 AM
MattFancher
The following code produces an error:
Public Sub Failure()
    Dim pMxDoc As IMxDocument
    Set pMxDoc = ThisDocument
    Dim pFeatureLayer As IFeatureLayer
    Set pFeatureLayer = pMxDoc.FocusMap.Layer(0)
    MsgBox pFeatureLayer.Name 'displays correct layer name
    Dim pFeatureSelection As IFeatureSelection
    Set pFeatureSelection = pFeatureLayer
    Dim pSelectionSet As ISelectionSet2
    Set pSelectionSet = pFeatureSelection.SelectionSet
    MsgBox pSelectionSet.Count 'displays correct count
    Dim pFeatureCursor As IFeatureCursor
    pSelectionSet.Update Nothing, True, pFeatureCursor 'this line produces an automation error
    Dim pFeature As IFeature
    Set pFeature = pFeatureCursor.NextFeature
    MsgBox pFeature.Value(2)
End Sub
The exact error message is:
Run-time error '-2147467259 (800040005)':
Automation error
Unspecified error
Any advice on what I'm doing wrong?  I'm working in ArcGIS 9.3.1.
DuncanHornby
MVP Notable Contributor
Try setting this line:
to:
pSelectionSet.Update Nothing, False, pFeatureCursor
Also help file says:
All edits to features that participate in a Topology or Geometric Network must be bracketed within an edit operation.
MattFancher
Duncan,
Thank you for the reply.  Unfortunately, I still get the error after making the substitution you suggested.  Also, no features in the map participate in a topology or a geometric network.
Matt
DuncanHornby
Matt,
What is the format of your data? I tried your code on some random shapefile I have and it worked. Your data isn't some sort of compressed (hence read only) dataset?
Duncan
