Problem with HTML Pop-up Configuration when trying to change target blank settings
1215
10-15-2020 02:10 PM
maplover
Hello everyone,
I am using ArcGIS Enterprise 10.8 and I have a web map with pop-ups which has a button that directs Survey123 in order to auto-populate it. With default settings (target="_blank") it opens in a new tab. However, I want to open this survey in the same tab and changed the html setting of target but i did not effect. Is there a workaround that I can do this?
Thank you so much for help.
