How to keep the order of the csv file when uploading it as a shapefile?
1336
10-12-2020 09:15 AM
AlliSelf
When uploading a CSV to Shapefile on ArcOnline, is there a way to keep the table in the shapefile and the associated dbf file in the same order as the csv file? When I open the shapefile table, the data is not in the same order as it was in the original csv. I can order it in the the table in ascending order, but when I save the shapefile and export to download, that sort does not get saved.
DanPatterson
MVP Esteemed Contributor
permanent sorts are only maintained when the sort tool is used on the data set
Sort (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
