Programmatically access user's Esri Python path
3480
10-07-2020 01:25 PM
DavidLaMartina
I'm creating a CoreHost app that needs to be able to call ArcPy scripts. To do this, we need (from what I understand) to know the local machine's python path - specifically the path of the python .exe installed with Arc Pro.
I've accomplished this on my development machine by just hardcoding the path to the ArcGIS directory in Program Files - but how can we get the appropriate executable without knowing where and how the user has installed Arc Pro?
Wolf
by Esri Regular Contributor
You can use the registry path HKEY_LOCAL_MACHINE\SOFTWARE\ESRI\ArcGISPro\PythonCondaRoot to retrieve the python root folder used by Pro.
DavidLaMartina
Thank you Wolfgang Kaiser‌. For others interested, this is the code I used to grab the path from the registry key Wolfgang provided:
RegistryKey arcGISProInstallDirectoryKey = Registry.LocalMachine.OpenSubKey(@"SOFTWARE\ESRI\ArcGISPro");
 object pythonDirectoryKeyValue = arcGISProInstallDirectoryKey.GetValue("PythonCondaRoot");
 string pythonDirectoryPath = pythonDirectoryKeyValue.ToString();
string localExecutablePath = @"Scripts\propy.bat";
 string pythonExeutablePath = Path.Combine(pythonDirectoryPath, localExecutablePath);
DanPatterson
MVP Esteemed Contributor
This works on a local machine, I don't know how you can access that information on another machine
import sys
sys.executable
'C:\\arc_pro\\bin\\Python\\envs\\arcgispro-py3\\python.exe'‍‍‍
In my  case, arcgis pro is installed in the c:\arc_pro folder
Addendum
which yields the same as the registry if you parse the \\envs... onward off
... sort of retired...
