aprx-file on a server
674
10-05-2020 12:39 AM
FerdinandFuchs
Hi there, are there kown problems working with the aprx-file (and gdb) of ArcGIS Pro located on a server? Not even simple tools such as "Feature Class to Feature Class" are working.
DeenaBowman
Hi Ferdinand, did you check for schema locks?  I've encountered this issue with some of the Departments I support.
FerdinandFuchs
Yes, schema locks are not the case (I'm referring to "read only" because of another user of the project.) It affects all writing tools inside the gdb. Every time. Although there's a general permission to write data to the drive e.g. shp-Export is working.
