open custom-widget by mouse left/right click on a feature
4607
8
10-03-2020 11:21 AM
MichaelLev
I use Web AppBuilder (Develper Edtion) 2.17, Launchpad Theme, on 3D Scenes (ArcGIS API for javascript 4.16).
Regularly mouse left click on a feaature opens feature default popup.
I don't want to change this, but how can I enable/disable an option that left click (or right click) on a feature will open my custom widget on that feature e.g. if I want to supply the user with query options on that feature?
RobertScheitlin__GISP
How to redirect the left click to not open the regular popup
I thought that was pretty clear from my previous reply. The link I provided shows how to prevent the standard popup from appearing.
As far as making your popup show instead you just simply add a view click listener.
Setting it back to the default popup is as simple as undoing what you did to prevent it.
MichaelLev
Dear Robert Scheitlin, GISP, no one has referred frm 3 Oct... Can you help, please?
MichaelLev
But I don't want to block or replace the default popup... I want that left-click on feature will still open the default popup, but that right-click on feature will open my custom-widget (or custom-popup) on that feature.
Michael,
   You are going to find very little info on adding a right click event to WAB as it is a very poor workflow choice. There is no right click on mobile, Apple is not a big supporter of right click, actually Windows is the main platform that uses right click. The few threads I have seen about adding right click to WAB normally they change their mind for a alternate workflow. But if that is your choice then the answer is just add a  view click listener and check the button property of the event.
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-SceneView.html#event-click
MichaelLev
Thank you very much, Robert, for this very  important insight!
So I have to use the left click, and have to be able to "choose" by some button, which popup will be opened, the default popup, or my special popup (or custom-widget).
How should I program this "switch" which will be opened by the left click?
That is completely up to you as the developer. Maybe a button in a widget or something.
MichaelLev
I'll make it clear what I ask: How to redirect the left click to not open the regular popup but my custom widget (and how to set it back to the regular popup, after I opened the custom widget)
