uncheck concurrent extensions when program closes
1461
10-02-2020 01:26 PM
MarkJohnson11
Having done in Desktop, using C#  I used the ESRI.ArcGIS.esriSystem .dll and there was a protected override void OnStartup() and OnShutdown method I could use.
In Pro I think the best I can use is ArcGIS.Core.Licensing.LicensingInformation.CheckinLicense(LicenseCodes.'extension') method. I cannot find or think up a way to check if the extensions have been used without the ArcGIS.esriSystem .dll.  I also cannot seem to find similar OnStartup() and OnShutdown() methods for the knowing when to run the CheckinLicense() methods.
Has anyone come across something similar to this? I am worried that even with the concurrent extensions, many of my co-workers might just check on the extensions and then never close the program, we have many more employees than extensions.
PascalVezina
Good day Mark,
I am doing something similar. I use the Expiration date to know if it's in use.
I use the Close Project event instead of the ArcGIS Pro.
public static bool IsCheckedOutProDataReviewer()
try
DateTime origin = new DateTime();
DateTime expire = new DateTime();
if (LicenseInformation.GetExpirationDate(LicenseCodes.DataReviewer) != null)
expire = (DateTime)LicenseInformation.GetExpirationDate(LicenseCodes.DataReviewer);
if (expire.CompareTo(origin) != 0)
return true;
else
return false;
catch (Exception ex)
MessageBox.Show(ex.ToString());
return false;
In the Module1.cs, I added this code... (Make sure that the autoLoad="true" in the insertModule in your Config.daml)
protected override bool Initialize()
try
ProjectClosedEvent.Subscribe(OnProjectClose);
return base.Initialize();
private void OnProjectClose(ProjectEventArgs obj)
try
ExecuteShutdownReviewExtension();
private void ExecuteShutdownReviewExtension()
try
if (ClassHelperReviewer.IsCheckedOutProDataReviewer())
    ClassHelperReviewer.DisableProDataReviewer();
protected override void Uninitialize()
try
ProjectClosedEvent.Unsubscribe(OnProjectClose); //unsubscribe
return;
