Plot times series graph like points using the Inforgraphic-widget, or another widget, in ArcGIS Online or Portal.
677
10-01-2020 06:09 AM
HaraldEriksen1
I would like to plot times series graph like points using the Infographic-widget, or other widget, in ArcGIS Online or Portal.
Because my data is organized with measurement data (y-values) in rows and dates (x-values) as column names the only way for the Infographic-widget is to not able to The only solution I have found is to choose «Display attribute values as charts» under Chart settings -> Data –> Display mode.
Under Chart settings -> Data –> Value fields   I select all the columns (with names representing a date ex. 20020322)
Unfortunately, in the resulting plot the measurements are treated as categories (not as dates) and displayed without gaps on the x-axis.
I am also missing the ability to automatic show trends in the widget.
Does anyone have succeeded using the Infographic-widget to show time series, or maybe there is a better way to do this?
