python expression
1555
09-22-2020 03:02 AM
GregorMitzlaff
Hello everybody,
in the picture you can see an attribute table of an heat meter. The number of the heat meter is 11250423. The heat status is given monthly. Now I want to make an expression to get the consumption of every month.
in theory I have to do sth like this:
y_(i+1)-y_(i) = consumption
Month 1 (january): y_(1+1)-y_(1) = consumption of January
Month 2 (feb): y_(2+1)-y_(2) = consumption of February
Month 12 (dec): y_(12+1)-y_(12) = consumption of December
does anybody know, how to write an expression in arcgis? I want to make a new field to calculate.
Thanks for helping.
Greets from Germany!
JoshuaBixby
MVP Esteemed Contributor
What application/environment are you working in?  Is the screenshot an ArcGIS Pro table?
DavidPike
MVP Notable Contributor
Id say order it descending then have a codeblock that gets the value for the row in WAERMEMENGE, stores it then does the calculation in the next row. I've not tested the below, and its been ages since ive done this so it's very likely horrifically wrong, but it may give you an idea.
##pre-logic:
def calculate_stuff(field):
    global previous_value
    result = field - previous value
    previous_value = field
    return result
##code window:
calculate_stuff(!WAERMEMENGE!)
Arne_Gelfert
Gregor,
I'm sure what you're trying to accomplish can be done in field calculator. In my experience, the more massaging I have to do with data, the more I want to do it near the source. Usually that's fastest and I find it more transparent. Don't know where you're getting your data. But this would be easy to do in SQL:
SELECT month(Datum) AS [MONTH], year(Datum) AS [YEAR], SUM(Wärmemenge) AS TOTAL
FROM <YOUR DATA SOURCE>
GROUP BY month(Datum), year(Datum)
-- ORDER BY [MONTH], [YEAR]
So admittedly, this may not work in in your situation but if it does and you can create a query layer or database view, I bet it would perform better.
Schöne Grüße
