ArcGIS Server 10.7.1: How to view log messages based on all levels (severe, warning, info, verbose, fine, debug)?
957
09-19-2020 10:14 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out if there is a way to view log messages based on all levels (severe, warning, info, verbose, fine, debug)
Jamal Numan
HamedFarzin
Hi Jamal NUMAN‌,
if I understood your question correctly, you set the level to "Debug"  and in this way will show all the calls to ArcGIS server.
on right top corner click on "Settings" and set the level of "Logs" you would like to capture.
Specify server log settings—ArcGIS Server | Documentation for ArcGIS Enterprise
Hope this helps.
Regards,
Hamed
JamalNUMAN
Thanks Hamed. Right. With the debug option all levels are populated.
Jamal Numan
