Close splash widget if a URL parameter is found
2815
5
09-18-2020 10:11 AM
MichaelKohler
I have a WAB that when opened, shows a splash screen widget.
There is a custom action on popups of a feature layer that sends an email to someone using the custom url parameters. Don't want to have splash screen shown when the recipient clicks on the link.
Is there a way to close the splash widget when url parameters are detected?
RobertScheitlin__GISP
Michael,
   Sure it would just take some custom code. What parameter are you looking for in the url?
Here is an example (lines 17, 20, 24, 25, 37-39):
define(['dojo/_base/declare',
    'dojo/_base/lang',
    'dojo/_base/html',
    'dojo/on',
    'dojo/keys',
    'dojo/query',
    'dojo/cookie',
    'dijit/_WidgetsInTemplateMixin',
    'jimu/BaseWidget',
    'dojo/topic',
    'jimu/dijit/CheckBox',
    'jimu/utils',
    'esri/lang',
    'jimu/dijit/LoadingShelter',
    'dojo/Deferred',
    'jimu/dijit/EditorXssFilter',
    'esri/urlUtils'
  function(declare, lang, html, on, keys, query, cookie, _WidgetsInTemplateMixin, BaseWidget, topic,
           CheckBox, utils, esriLang, LoadingShelter, Deferred, EditorXssFilter, urlUtils) {
      postCreate: function() {
        this.urlObject = urlUtils.urlToObject(window.location.href);
        this.urlObject.query = this.urlObject.query || {};
      onOpen: function() {
        if (!utils.isInConfigOrPreviewWindow()) {
          var isFirstKey = this._getCookieKey();
          var isfirst = cookie(isFirstKey);
          if (esriLang.isDefined(isfirst) && isfirst.toString() === 'false') {
            this.close();
        if(esriLang.isDefined(this.urlObject.query.closeSplash) && this.urlObject.query.closeSplash == "true"){
          this.close();
Tags (1)
Michael,
    'dojo/_base/lang',
    'dojo/_base/html',
    'dojo/on',
    'dojo/keys',
    'dojo/query',
    'dojo/cookie',
    'jimu/BaseWidget',
    'dojo/topic',
    'jimu/utils',
    'esri/lang',
    'dojo/Deferred',
    'esri/urlUtils'
            this.close();
          this.close();
Tags (1)
MichaelKohler
I'm really just interested of the existence of a query parameter in the url.
So just change my code example above to line 36 to
if(esriLang.isDefined(this.urlObject.query.query)){
(yes two "query"s as the first query is just the object name that the browser gives to anything after the ? or & in the url).
MichaelKohler
So I ended up doing this:
?query=cipgis_144_373,CIPNumber,UTIL-UG-2019-17&closeSplash=true
Thank you!!!
ODWC_GIS
I know it is much too late to ask for elucidations, but where exactly would this custom code go
  • Where does this code get inserted?
  • How do you access that location?
  • Is there some kind of a graphical representation that would explain to me how/where this stuff is connected/arranged?
I'm in a similar spot: I'd like the WAB's Splash Widget to not deploy when URL Parameters are present.  It would solve a major problem I've got at the moment.  ...I just don't recognize your solution. But I'd like to!
