Image adding in Service
777
09-18-2020 12:03 AM
SrinivasaRao1
Can anyone please let us know if it is possible to add geotagged images in ArcGIS online services? as when we publish Image (blog/raster) got disappeared after publishing the service to ArcGIS online and checked with ArcGIS Portal as well.
Reagards,
Srini
ManishPatel
Srinivasa Rao‌, yes you can add geotagged images. You can refer to the Add geotagged photos to your web map blog which details the steps.
Before uploading please ensure that the photos have location information, if the photos do not have the location information then it will be ignored.
I have a sample web app showing the geotagged photos uploaded to ArcGIS Online. https://arcg.is/r5HT0
Hope this helps.
Cheers,
Manish
Cheers,
Manish
SrinivasaRao1
Thanks for providing details, this was known to us.
We are doing one sample application in WAB where we select folders containing geotag images and it would read coordinates from image and create a service in ArcGIS Online or Portal which we have already provided empty service, so in this process, coordinates are copying into feature class or service created but image blog or raster file could not be added in ArcGIS online or portal. So we require if there is any other process other than above.
