Join questions without related table
1361
09-15-2020 08:49 AM
SMauri
Hi all,
my goal is to aggregate several question in one column, with a comma as separator.
So I insert a Repeat section in my survey. But I don't want any related table in my structure. So I insert null as parameter in bind::esri:fieldType column, as you can see below.
typenamecalculationbind::esri:fieldType
begin repeatRepeatSectionRepeatnull
textMyQuestionMy Question
end repeat
textQuestionJoinjoin(",",${MyQuestion})
Unfortunately the table is present in the structure.
Is this an expected behavior?
Thank you
Stefano
IsmaelChivite
Esri Notable Contributor
Hi. This is expected behavior. The null value in bind::esri:fieldType will be ignored by repeats.
SMauri
Hi Ismael,
thank you for quick reply.
Can you suggest me any workaround to get the required goal?
Cheers
Stefano
