Customize keyboard navigation ?
1624
09-10-2020 07:40 AM
VictorBerchet
The key bindings used for navigation with the JS API are specific to ArcGIS.
It seems like most other platform (Google Earth, Google Maps, Cesium, ...) use Shift + Left click to rotate the view around the camera center. The only way to do that with the JS API is right click + drag at least when the device has no touch screen.
Rotating becomes a pain when you only have a touchpad.
It would be super nice to be able to override the key bindings to add custom ones.
Is there any plan ?
Thanks for this great API.
VictorBerchet
For now I have solved my problem using the following code:
const toggle = view.ui.find('navigation-toggle') as NavigationToggle;
view.on('key-down', (e) => {
if (e.key == 'Control' && !e.repeat) {
toggle.toggle();
view.on('key-up', (e) => {
if (e.key == 'Control') {
toggle.toggle();
