Hi all,
I'm pretty new to arcGIS Pro so go easy on me. I'm trying to combine two rasters (.tif format) using the Combine tool in arcGIS Pro 2.4. The first raster is a map of US land cover at a 30x30m resolution (roughly 8 billion pixels). The second raster is US counties. There most common error I get when I try to do this is:
ERROR 010159: Unable to open VAT file of C:\cdl\combine_cdl.tif.
ERROR 010067: Error in executing grid expression.
Failed to execute (Combine).
I've tried shortening path lengths and making sure I have permissions to the drive. Also when the tool fails no file, VAT or anything else, is created. I've also tried moving files inside a local geodatabase with similar results.
Essentially, I'm trying to spatial merge the two files so that I have County FID's associated with land cover. Next steps involve joining data based on FID and landcover to heatmap. If there is a better way to go about this please let me know. I've tried vectoring the land cover raster by doing Raster to Point>Fishnet>Feature to Polygon to get a shapefile to work with, but the 8 Billion values exceeds arcGIS Pro's limit.
Any input is much appreciated.
Combine is likely not a good idea as it would generate unique IDs for every land cover /county combination, and be pretty meaningless unless you were doing it within a scripting environment/workflow.
I would really question why you need to do this is the first place, is the heat-map already created? If so - I think back-filling everything into the heatmap is much much harder than recreating it.
The heat map is the end goal of this project. Essentially I have a table of dollar amounts by land cover type and county FIPS. I'm trying to use the 30x30m raster land cover file as the resolution for the dollar amount heat-map. I was trying to somehow merge my dollar data table with a counties raster file and then merge that to the land cover file so that I would have dollars associated with each land cover pixel for heat-maping. All land cover dollar values are the same within each county.
I have created a mosiac dataset of the two raster files (counties and land cover) but am struggling how to merge my dollar data to them and how to create a heatmap from this.
