Retrieve table cell value from context menu
1314
08-19-2020 02:15 PM
MarvisKisakye1
I have inserted a custom button (FilterRows) into the right click context menu of a table cell as below.
<updateModule refID="esri_editing_EditingModule">
      <menus>
        <updateMenu refID="esri_editing_tableCellContextMenu">
          <insertButton refID="FilterRows" separator="true" insert="after"
               placeWith="esri_editing_tableCopyCellButton" />
        </updateMenu>
      </menus>
    </updateModule>
I need to retrieve the value of the cell that the user right clicked on. I suspect that I need to retrieve the TableControl that the user clicked on and retrieve the cell value that way. But how do I retrieve the TableControl? Uma HaranoWolfgang Kaiser
UmaHarano
Here is a code snippet you can use to retrieve the values.
public static Task<object> ActiveCellContents()
      if (FrameworkApplication.Panes.ActivePane is ITablePane tablePane)
        var mapMember = tablePane.MapMember;
        var oid = tablePane.ActiveObjectID;
        if (oid.HasValue && oid.Value != -1 && mapMember != null)
          var activeField = tablePane.ActiveColumn;
          return QueuedTask.Run<object>(() =>
            // TODO: Use core objects to retrieve record and get value
            return null;
      return Task.FromResult<object>(null);
Uma
UmaHarano
            return null;
Uma
MarvisKisakye1
Brilliant! Thank you!
