Is there a way in modelbuilder to use the same initial feature (call volume) and run a select by attributes on that layer multiple times to generate unique optimized hotspot analyses?
1119
08-14-2020 09:10 AM
SteveGuiry
I have 27 individual ID's and want a hotspot analysis for each one to identify where to customize potential polygons, but the way i've run model builder it ends up running all 27 select by attributes one after another before moving further into the model. I'd like to run one process from start to finish, then the next and so on.
DuncanHornby
MVP Notable Contributor
Steve,
I'm afraid we are not mind readers, if you have created a model and it's not working as intended you need to show people what you have done! Suggest you edit your question and add some screen shots as when you say "the way I run model builder" then that could be 100 different ways...
