ArcGIS Maps in Excel
1344
08-12-2020 03:40 PM
AnareMOTOKULA
I am trying to add data to my sharepoint excelsheet add on @ArcGISMaps in excel however I cant seem to find my country when I am trying to specify locations and use the data from the excelsheet. The data collected is based on the provinces (admin boundary) of my country but I cant seem to add this as a boundary because my country is not even an option to add. I'm from Fiji by the way.
DerekLaw
Esri Esteemed Contributor
Hi Anare,
Can you please clarify: are you using ArcGIS Maps for SharePoint or ArcGIS Maps for Office? The latter is the add-in that works within MS Excel - but you've posted in the discussion forum for the former.
Can you please describe your workflow in more detail, perhaps provide screenshots?
AnareMOTOKULA
Hi Derek,
I have primarily been trying this in  ArcGIS Maps for Office. And as seen below in the location type I would like to choose Fiji Admin Boundaries but this is not possible as Fiji is a country still not on here as an option.
Cheers
Anare
DerekLaw
Hi Anare,
Thanks for the clarification. In the Data format dialog, after you select the records in your spreadsheet that you want to geocode; then in the Add data with location and map style dialog, for the Location type parameter, is Country not an option for you?
> The data collected is based on the provinces (admin boundary) of my country ...
I'm unsure if the world locator service has admin boundaries for Fiji.
Hope this helps,
