How to create a list out of an array for a SQL IN Operator
2466
08-12-2020 12:08 PM
TL2
I have a arcade expression that loops through a set of records and produces a comma separated list of parentrowids.
    for (var p in parentrowids) {
        array +=    p.parentrowid + ", "   ;
var prid_array =  array;
I have a where clause a few lines down that uses the IN operator to filter on another table.  I get this error not matter how I try and produce the "array".
When I write the value to a table using this string:
var prid_array =  "('"+ array + "')";
I get this:
However the table is populated as
('{67D92A25-79C7-4225-9AD1-C140662DEFCF}', '{F269CECB-70D3-4288-8D11-102025D3D701}', '{99AB8E1B-2759-43CA-88DE-7A5A2FDECDC6}', '')
Is there a way to output a string to be used in a IN operator?
Xander Bakker
Tags (3)
XanderBakker
Esri Esteemed Contributor
Hi T L ,
No sure if I would use a SQL expression with IN on GlobalIDs. It may requiere some additional formatting. If I apply some of the logic that I have used before it could be something like this:
var prid_array = "uniquerowid IN (";
var lst = [];
    lst[Count(lst)] = "'{" + Upper(p.parentrowid) + "}'";
prid_array += Concatenate(lst, ",") + ")";
However, I think since you are working on GlobalIDs there will probably be a relationship, so maybe you could get the related features for each of the GlobalIDs from the list and process them as you need.
XanderBakker
Hi T L ,
Just an additional comment. When I need to verify if the syntaxis of a SQL is correct, I normally use Pro and construct the definition query and switch to SQL to see how it is formatted:
