Image Widget and Layout Functionality
2170
08-06-2020 09:50 AM
Dunn_Jeremy
Good Afternoon
I have a number of image widgets that I have put into a row widget to try and lock them down in my layout. However when I resize my browser window these image widgets move. How can I lock the the image widgets so they honour the position they are within the Edit frame ? Locking down each image widget, row widget and finally the layout does not seem to work.....
Regards.
Jeremy.
shaylavi
Hi Jeremy,
Have you tried using the column widget? you can add the row widget (containing the images), inside a column widget, then spread the width across all available columns and it should be responsive based on the size.
The columns widget is based on a design principle of 12 columns layout system. This allows better flexibility when designing web pages and there are similar principles when developing content for mobile apps.
Shay.
Shay
Dunn_Jeremy
Afternoon Shay,
Yes I use the images in a row widget....however this still doesn't behave as I would like. Resizing the browser window does still cause some issues....applying a row widget does help.
Thanks for the insight.
Regards.
Jeremy.
shaylavi
Jeremy,
I referred to the column widget as a wrapper to the rows widget. The rows widget is not meant to be responsive.
You can read more about this in the documentation -
Column widget—ArcGIS Experience Builder | Documentation
Shay.
Shay
