Save Layer Styles
2143
08-05-2020 11:41 AM
HeatherHerrmann2
Hello.
I am curious if there is a function in ArcGIS Online that will allow me to save layers as if I were saving a layer file in ArcMap?  I think it would serve me well to have something like that for layers I use regularly instead of having to manually change each feature to the custom symbol I like to use.
Thank you in advance for your feedback.
Katie_Clark
MVP Regular Contributor
Hi Heather,
If you want layer settings (symbology, pop-ups, visibility range etc) to be maintained no matter what map the layer is pulled into, you can make changes at the layer level in the Visualization tab of the Item Details page.
Hope that helps!
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Hi Heather,
Hope that helps!
Best,
Katie
HeatherHerrmann2
That's exactly what I was looking for!  Still getting my feet wet in AGOL and really enjoying it so far. This will save a lot of time!
Thank you so much Katherine!
Katie_Clark
Glad I could help! Don't forget to make sure to mark this question as answered to close it out.
Best,
Katie
