Public Notification Widget Record Limits
2467
08-04-2020 01:10 PM
by Anonymous User
Not applicable
Is there a way to remove the 1,000 record limit in the Public Notification Widget in WebApp Builder or the Public Notification Solution?
HarishPalaniappan
See if this helps you to update that limit for your needs - https://support.esri.com/en/technical-article/000012383
HarishPalaniappan
cedwards
This solution is currently 404'd can you update that?  I would like to know how to fix this issue
dgregory_coconino
Yes, would love to know the answer to this problem. It looks like the original support link was taken down.
by Anonymous User
Not applicable
This did the trick!  Thank you for pointing me to that article.
