Developer Edition v1.1: Output format not supported
6323
8
08-01-2020 05:24 AM
Ranga_Tolapi
Steps followed:
  • Created a new experience
  • Selected Launchpad template
  • Clicked on the Map 1 element
  • From the right-side panel, clicked on Select map
  • Clicked on Add new data
  • Selected a Web map from My content
  • A pop-up appeared with the below message
Error: Output format not supported.
Code: 400
  • Refer to the enclosed screenshot
This issue was not experienced with ArcGIS Experience Builder Developer Edition v1.0
Jianxia SongDavid MartinezDan Jiang
DavidMartinez
Can you provide us some additional details about this service? What version of enterprise, what is in the map service? Can you share it with us? My username is dmart.
David
Ranga_Tolapi
David Martinez thanks for your response.
ArcGIS Enterprise version 10.8.0.
What we observed is, at the time of getting error, both the Web Map and it's corresponding Map Image Layer were shared to No One. Once shared both the portal items with ArcGIS Enterprise, not getting this error any more. Does this make sense!
Surprised, even when the portal items were not shared with any one, it's worked fine with ExB Developer Edition 1.0.
DavidMartinez
Thanks, we are trying to reproduce and will get back to both of you.
AzinSharaf
hi David Martinez‌ do you have any update on this case? I am experiencing same issue.
DavidMartinez
Hi Azin,
We have an opening issue on this and will get it fixed for the upcoming release.
Cheers,
David
AndreasEugster
I'm facing the same problem with WebScenes.
Strange thing:
Trying to add a WebScene (Own Basemap + 3D Buildings - shared No One) in ExB Developer Edition 1.1 leads to the described error... but adding the "empty Webscene" with only the Basemap to the Experience(1.1) works. Now you can can update/overwrite the WebScene with other layers within the ArcGIS Enterprise and everything loads as supposed within the ExB DevEdition 1.1... any ideas ?
AlexanderMayer
Hello everyone,
The bug is still being processed?
We use the ArcGIS Enterprise version 10.8.1 and get the same error as described above with a WebMap.
Is there already a known solution for this?
Kind Regards
AndreasEugster
As said by David "We have an opening issue on this and will get it fixed for the upcoming release."...
didn't hear anything about the release date so far.
I worked around by
A) Creating an empty scene, add the empty scene to the experience (that works), update / rebuild / change the scene - it seems like only the initial "adding" of scenes with content is the problem
B) .... place the scene into an WebAppBuilder Application, embed the WebAppBuilder Application in the Experience... questionable of course, but works for me until it will be fixed
