Using Field Calculator with iif statement, I get "Cannot assign to const value". Why, please?
2271
5
07-28-2020 09:00 AM
NancyDorsey
Arcade statement:
IIf($feature.HOLE = "HORIZONTAL",1,2)
Error: Arcade cannot assign to constant value.  Why?  I am trying to set up weighting criteria.  I tried setting the field to both long and short numbers, but still get errors.  All help appreciated.  thank you.
JoshuaBixby
MVP Esteemed Contributor
Try:
IIf($feature.HOLE == "HORIZONTAL",1,2)
JoshuaBixby
Try:
NancyDorsey
That worked, thanks!  Too bad ESRI has it wrong or incomplete in their documentation!  Thank you again!  CORRECTION: ESRI does have it correct, I was not using the Arcade syntax but thinking of the Desktop simple and obvious language no longer used.  Sigh.  New tricks are hard.
JoshuaBixby
Please close out this question if everything is working for you.
NancyDorsey
I don't know how...though it looks like I have.
KenBuja
Where is that incorrect in the documentation?
