Survey 123 Survey forms stuck in outbox on ipad (7th generation) and iphone message 'getting service information' but submission never completes. Advice please?
1105
07-27-2020 08:00 AM
KateSurry
Two surveys have been successfully sent from iPhone previously.  Now 13 surveys  (containing 3 images each) stuck in  iPhone outbox  and 42 on ipad. Is it possible to send surveys one at a time if an issue with data transfer?
EricRodenberg
Support has workflows to help you recover data stuck on a device and get it to the feature service you are trying to edit..  Whatever you do, don't delete the surveys till support has helped
Eric J. Rodenberg | Solution Engineer Transportation Practice
Esri | 7775 Walton Pkwy, Suite 270 | New Albany, Ohio 43054-8202 | USA
T 614-933-8698, ext. 5503 | erodenberg@esri.com | esri.com
KateSurry
Thanks Eric I will keep trawling.
