Python command prompt not starting
2496
07-25-2020 05:56 AM
NiklasHausmann
I am trying to work through this tutorial and got to the part where deeplearning tools had to be installed into a new environment via the python command prompt. However, the command prompt immediately closes again.
I reinstalled ArcGISPro (2.5) multiple times but had no luck. Running the proenv.bat in ArcGIS/Pro/bin/Python/Scripts as administrator (as suggested elsewhere) did not help. Sadly the window closes so quickly that I cannot read what it said.
I played around with some other ways of installing the tools into a new environment, but given that I know next to nothing about python it seemed to be of little help.
I figured that something during the installation didn't work out properly and I tried to see whether default environment was working ok following instructions here:
from arcgis.gis import GISmy_gis = GIS()m = my_gis.map()m
Which worked fine and displayed the map as expected.
Any suggestions on what to try next?
DanPatterson
MVP Esteemed Contributor
have you activated your cloned environment through arcgis pro's package manager or via conda?
... sort of retired...
NiklasHausmann
I have activated it via the package manager. It didn't seem to make a difference.
I should say that I ran the code that I quoted above via the Jupyter Notebook in the start menu not as was suggested via the python command prompt.
NiklasHausmann
OK, I solved the issue by deleting a corrupt file called ".condarc" which was in my user folder and I assume the product of a different installation.
Thank you Dan for your initiative!
