Filter of parameter for python tool?
2338
6
07-24-2020 08:29 AM
MinaAlsaad
Hello, I have different methods within the same script tool how I can apply filter so that the user will select different method and run code
DanPatterson
MVP Esteemed Contributor
for one of your parameters, define it as a text parameter and make a value list with your options.
For each option, create a def that performs the task
import blah
method = arcpy.GetParameterAsText(0)  # a value list of the method names
params = arcpy.GetParameterAsText(1)
def method1(params):
    """method1 functionality"""
    Do stuff
    return something
def method2(params):
    """method2 functionality"""
    Do stuff
    return something
if method == "first":
    result = method1(params)
else:
    result = method2(params)
print("Here is the amazing result : {}".format(result))
... sort of retired...
MinaAlsaad
Dan Patterson‌ Thanks for your reply, what I want to do to call one function rescale (input, mode, other parameters)
inside mode there is different method {edge, warp,}, if the user select one of the method it will be different result ?
MinaAlsaad
Dan Patterson‌ What I meant only I want to change one parameter and run the tool?
JoshuaBixby
Mina Alsaad‌, I read your question and your responses, and I am having a hard time figuring out your question.  I realize there may be a language barrier occurring, but that makes it even more important to provide specifics and examples rather than speaking in general.
MinaAlsaad
Thanks for your reply, Sure I am trying to use ready function that need arguments such (raster, scale , and method)
what I need the user to select the method from drop down menu and run the tool ?
JohannesLindner
If I understand you correctly, you have a function with 3 parameters:
  1. input raster
  2. scale
  3. a method which changes how your function manipulates the raster
To use this function inside a script tool, you have to define 3 parameters for the tool:
  1. input raster
  2. scale
  3. method
In the method parameter, define a filter list with valid method names. This way, you have a dropdown list with predefined things like "warp", "edge", etc.
Then you change your script:
# imports
# get the script parameters
raster_param = arcpy.GetParameterAsText(0)
scale_param = arcpy.GetParameterAsText(1) # convert to int or float as needed
method_param = arcpy.GetParameterAsText(2) # this parameter has a filter list,
                                           # so you know it can only be "warp" or "edge".
# define your function (I think you already have that)
def your_function(raster, scale, method):
    # stuff
    if method == "warp":
        # warp implementation
    if method == "edge":
        # edge implementation
    # more stuff
# call your function
your_function(raster_param, scale_param, method_param)
Have a great day!
Johannes
