Geoprocessing service to return a file
9737
12
07-21-2020 01:50 AM
VictorTey
How can I get a geoprocessing service to return a file?
I published a GP
if __name__ == '__main__':
    file = open(arcpy.env.scratchWorkspace+ "/" + "test.txt","w")
    file.write("why")
    file.close()
    arcpy.SetParameter(0, file.name)‍‍‍‍‍‍‍‍‍‍‍‍
however i kept receiving the
 "value": "d:\\arcgisserver\\directories\\arcgisjobs\\script_gpserver\\j94a7e5b06f3342deb0ebcb65467f63fe\\scratch/test.txt"
I can see the file in the scratch folder but i need to return the file some how.
I did try to access the file via different permutation of
https://example.com/arcgis/rest/services/Script/GPServer/Script/jobs/j94a7e5b06f3342deb0ebcb65467f63... to no avail
Can someone kindly assist.
BruceHarold
Esri Frequent Contributor
Victor, the team here notice your output data type is GPString, please change it to GPFile. it should then work.
Egge-Jan_Pollé
Hi Victor Tey,
Why do you put a forward slash between the path and the file?
What happens if you replace this "/" with "\\"?
Does this solve your issue?
BR,
Egge-Jan
VictorTey
I had rewritten the code several times
txtFile = os.path.join(arcpy.env.scratchFolder, "myTxt.txt")
f = open(txtFile, 'w')
f.writelines("huh")
f.close
arcpy.SetParameterAsText(0, txtFile)
One of them is as shown above, still the same .
I have arcgis enterprise installed locally, would that have made a difference?
DanPatterson
MVP Esteemed Contributor
This number differs from the one in the your image... is that supposed to happen?
... sort of retired...
VictorTey
My apologies, I had so many tabs opened and I must have copy and paste from the wrong tab
    f.writelines("huh")
    f.close
    arcpy.SetParameterAsText(0, txtFile)‍‍‍‍‍
BruceHarold
VictorTey
Spot on, thank you so much , this is my first attempt working with publishing GP and trying to piece together how everything works together
BruceHarold
Superseded by my comment above but still useful!  To answer your original question, to return your output file parameter (in Pro) wrap the web tool in a model and add the Copy geoprocessing tool to copy it into your project.  The file has to be a supported type.  Here is an example where the web tool is a Spatial ETL tool which I featured in my recent UC technical workshop on Data Interoperability extension.  The experience of a web tool output going to a rather obscure profile directory is under review by geoprocessing team.  Note:  The intermediate scratchfile will be deleted when you exit Pro, this is also under review.
VictorTey
Thank you all for your help. It turns out I have been really silly.
I kept attempting to access the file via  "arcgis/rest/services/
arcgis/rest/services/Script5/GPServer/Script/jobs/j24670b8fb4944b60993fa840472bc2f8/results/URL
where else the output of the directory is actually on arcgis/rest/directories/arcgisjobs
arcgis/rest/directories/arcgisjobs/script5_gpserver/j05515f60833c4e15a8d461f40acb1484
Marc_Alx
For further reader, here's a sample geoprocessing toolbox with a tool that returns a file.
Some notes
- Your parameter file must have a "direction" of "Output" and a "parameterType" of "Derived"
- The file type for geoprocessing parameter is "DEFile", for some reason "GPDataFile" results in no file being accessible to end user. Once published it appears as "GPDatafile"
- Result must be set via arcpy.setParameterAsText whereas setting "value" of a saved parameter does nothing.
- In order to be accessible you file must be wrote/saved to "arcpy.env.scratchFolder". Arcpy rewrite this path once published to an accessible URL.
- If you wish to backup your file outside of "arcpy.env.scratchFolder" you have to register the save location, from ArcGIS Pro: add any folder you need via: Share→Manage→Data stores, here add a new `folder` with `Publish folder path` set to the path you want to expose. Keep in mind that any hard coded path will be consolidated (to a sandbox path) on publish by ArcGIS.
 Some useful links
Authoring web tools with Python scripts (to understand path consolidation)
- Publish web tool
The code
# -*- coding: utf-8 -*-
import arcpy
from os.path import join
class Toolbox(object):
    def __init__(self):
        """Sample file toolbox"""
        self.label = "Sample file toolbox"
        self.alias = "File toolbox"
        # List of tool classes associated with this toolbox
        self.tools = [GetFileTool]
class GetFileTool(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Get file tool"
        self.description = "A tool to get a file"
        self.canRunInBackground = False
    def getParameterInfo(self):
        """Define parameter definitions"""
        return [arcpy.Parameter(displayName="Output_File",
                                name='Output_File',
                                datatype=['DEFile'],
                                parameterType='Derived',
                                direction='Output')]
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def exitWithError(self,msg):
            exit geoprocessing with a given error msg
            under the hood it raise an exception, msg is logged as error
        raise ValueError(msg)
    def execute(self, parameters, messages):
        """The source code of the tool."""
        p = join(arcpy.env.scratchFolder, "test.txt")
        with open(p, 'w') as f:
            f.write('hello')
        #set result with SetParameterAsText, setting result via 'value' parameter of objects inside parameters does nothing
        arcpy.SetParameterAsText(0,p)
