Multiple Feature Classes to One Related Table
4060
8
06-24-2020 10:34 AM
TylerHaladuick1
I have a point, line, and area feature class that I want to relate to one monitoring table.
I have created GlobalID in the feature class and GuID in the table.
Simple relationship classes between each feature and the table using 1:M, GlobalID to GuID, and forward messaging.
Feature Class Area > Simple Relationship Class 1:M, GlobalID to GuID, and forward messaging > Monitor Table
Feature Class Line > Simple Relationship Class 1:M, GlobalID to GuID, and forward messaging > Monitor Table
Feature Class Point > Simple Relationship Class 1:M, GlobalID to GuID, and forward messaging > Monitor Table
This works as designed in the ArcGis Pro desktop but when published and used in Collector I get the error "1 or more attributes failed to submit" when trying to add a related event.
Is this functionality possible? Am I doing something wrong in the configuration? I don't particularly want to create a static merge after the fact...
Thanks!
Tyler
MichaelDavis3
Hmm - I know we've done something similar in the past... essentially creating a single inspection feature class related to multiple parent feature classes.  Is it possible you are having issues with the data types in your ID fields not matching up?
TylerHaladuick1
If I have one feature relate only to one table it works perfectly (i.e. Area>Relationship>Table), but adding multiple relationship classes seems to break it in Collector. How did you set up your related IDs, did you use global to GuID or something different?
DougBrowning
MVP Esteemed Contributor
I have 9 to 13 related Feature classes to one main feature class and it works fine.  I use my own IDs though and not globalid.
I do not use globalids for keys for all the reasons in this post https://community.esri.com/thread/166958
Hope that helps
JMitchell
I am having the same issue described using Field Maps and the Edit widget in the Web App Builder; when trying to add a record to the related table under this exact setup, the application(s) are unable to submit.
Is there an explanation for why a GloablID related to a GuID may not function properly within this setup?
I posted my own question asking this: https://community.esri.com/t5/arcgis-field-maps-questions/unable-to-submit-records-to-related-table-...
SveinungBertnesRåheim
I tumbled around with this issue for a while. The problem seems to be same name on the ID-attribute fields.
I have to feature classes with defined relationships to one inspection table. The relations are based on GlobalID. My solution was to define different attribute fields in the relate-table. The relationships are:
GlobalID -> GUID_Polygons
GlobalID -> GUID_Points
In my original setup, I had the same attribute field - GUID. The relations worked fine in ArcGISpro. In Field maps, I saw established relations, but could not add new.
With this new setup, I can add and delete features and rows in Field maps. And I can take data offline.
Kklitt
I've been struggling with this and just stumbled across your answer. My setup works perfect now. Thanks!
MicZatorsky_AEC
Can anyone recommend an article/tutorial/blog that walks through the end-to-end process of setting up a related table, as discussed above for ArcGIS Pro 3.1.x?   The Create Relationship Class documentation is insufficient by itself.
I have created a composite relationship between a point feature class and an attribute table  (composite because I want cascading deletes),  but I'm a bit clueless about what happens next in Pro as far as the configuration and editing workflow.  I'd like to learn how to add records in parent and child fc/table, populate keys, configure popups, and what does messaging really mean?
KumuduDesilva
Can I please know any of you see this error, when you open the attachments on the AGOL? when you combine multiple relationship tables to One feature.
"error":{"code":404,"message":"Unable to complete operation.","details":["No Attachment found."]}}
