Survey123 website - Default (Open in Map Viewer)
1671
06-15-2020 01:02 AM
Hussam_AlJabri
Hi All,
Regarding of the limitations in appearing the attachments of repeat question in Survey123 Website I need to know if there is a way to set a default Map Viewer in (Open in Map Viewer) so the end user can see the attachment of the repeat question in the portal as a temporary solution until the limitations break.
so, please share your ideas if anyone has a workaround solution. James TedrickIsmael Chivite
JamesTedrick
Esri Esteemed Contributor
Thanks for clarifying.  We are looking into ways that a specific map can be used with the Data Tab.
JamesTedrick
Hi Hussam,
Apologies for the delay in response.  The 'Open in Map Viewer' will open the ArcGIS Online/ArcGIS Enterprise Map Viewer - are you asking for it to open a specific map?
Hussam_AlJabri
Hi James,
Yes I am asking for it to open a specific map.
JamesTedrick
Hussam_AlJabri
Yes James, let us specify the map and manage it. This function will give us the capabilities to share the data with desired map viewer.
Many thanks for your cooperation. Can't wait to meet you at Esri UC 2021!
