how to do math on string fields
3805
7
06-11-2020 09:00 AM
Matt-Barrett
I have a drain pipe layer that includes fields for upstream elevation, downstream elevation, and length.  I want to calculate the slope.  However, the fields are all string fields.  Is there a way to do this in ArcGIS Pro without adding or otherwise changing the fields?  I remember in the old days with avenue you could use a thing like {field}.asnumber or {field}.asstring to a calculate function to do stuff like this, but I don't know if there's a way to do it in Pro.  Thanks!
Robert_LeClair
Esri Esteemed Contributor
Related you could use the field calculator with Python and the float() function then.
JoeBorgione
Use the field calulator with python and the int() function.
Matt-Barrett
Thank you.
But would that round up my decimals?
Robert_LeClair
Matt-Barrett
that sounds perfect!  Thanks!
JoshuaBixby
MVP Esteemed Contributor
Please mark one of the replies as correct to close out the question once you get it working.
Matt-Barrett
So I used the float function.  It mostly worked.  Ended up with values in scientific notation.  Got it worked out in the end though, so thank you to those who replied.
JoshuaBixby
Matthew, I unmarked your reply and marked Robert's as the answer since your comment saying thanks isn't really the answer to your own question.
