Where are Attribute Rules stored in an Enterprise SQL database?
3476
06-12-2020 11:09 AM
TL2
I figure they must be some soft of trigger or sp but I cant find them.
Thanks.
Jared_Motuz
Attribute Rules are stored in the GDB_Items system table. Specifically, within the definition column of the feature class that the Attribute Rule is applied to.
Geodatabase system tables in SQL Server - Tables that implement enterprise geodatabase functionality
FAQ: How do I query the DEFINITION column of the GDB_Items table in a SDE geodatabase?
cf_gis
So do I need to have all connections to my database terminated in order to add an attribute rule?  I have a lot of layers to transfer rules to.  If not it seems odd that I can't do this while other connections are active.
